Old Jul 30, 2018 | 01:23 PM
  #42 (permalink)
jamesmonter2's Avatar
jamesmonter2
Default Re: Cylinder Misfire Help
Guys,
What is the seal called that is attached to the bottom of the engine cover that seals tight to the mas air flow sensor. I cannot find a place to buy this seal. Mine has some dry rot which may be causing a slight air leak. Anyone know where to buy this? I checked ebay but could not find a match. Thanks. Also I have the crank shaft position sensor on order. I will update after I replaced that.
