Ed Mahoney
BAS/ESP light on , did this fix your problem replacing brake pump pressure sensor ??? Where is sensor located ?
Ed, there is a pressure sensor on the master brake cylinder; you can check to be sure the connection is clean and tight. It has also been found that a bad brake light switch will cause the BAS/ESP light to go on, but that usually also deploys the wing on the limiteds. Do not know if you have a SRT or N/A. The brake switch is near the brake peddle in the drivers footwell. Any codes?
