Old Aug 4, 2018 | 11:51 PM
Auto's Avatar
Auto
Default Re: Changed SKREEM, key & ECU no start!
Hello and thank you for replying.
To follow up on your questions, yes. I replaced ECU, transponder chip in the key fob w/ matching internals, key ring and SKREEM module. Everything matched the exact numbers with my original equipment also.
A little info about myself as well... I've been installing electronics and accessories professionally for 25yrs. Such as remote starts, alarm's and etc but, I'm stumped on this one.
I think the factory security is what the issue is because, of the following reasons:
When connecting the battery the security starts flashing the lights and will not allow me to shut it off by the unlock button on the remote. It will however stop flashing when I depress the lock button. I have tried programming the remote again and again. I have removed fuse 9, nothing. I have left it set for one hour with key on in the ignition, doesn't work.
There has to be something I'm not doing right.
