Old Aug 5, 2018 | 09:53 AM
Auto's Avatar
Auto
Default Re: Changed SKREEM, key & ECU no start!
No codes even with the original SKREEM & ECU.
No water. Haven't checked any inertia sensors, didn't know of any. Have been searching this Forum and others for two weeks. I've never owned nor have I ever worked on a CF.
***The original SKREEM and ECU would lock and unlock(arm/disarm)doors with no problem. The donor set will only lock(arm). Both however will not start the car and on the third attempt the car quits cranking. Car will fire and run with a little gas in the throttle body but dies when that runs out.
