zip439
If you are getting the security model (central locking model) you may as well play it safe and get the Body Control Model from the donor car as well. The central locking model "talks" to the BCM with the OK of the SKREEM. Hope you are getting all these really cheap as a new SKREEM from Needswings is about $250
Don't know yet. Should've went that route but I bought it tore down already. The previous owner changed the ignition because it locked on them and after that it wouldn't start. Only reason I bought the used stuff is because I got a LH headlamp, engine cover, ECU and SKREEM for $270.00. was thinking headlamp was worth that.
