onehundred80
Taking my statement on its own could be confusing but when taking it in context with your statement which I quote it is obvious. For the price you paid I said you should have purchased the other headlamp if it was available, that is what I said because I am aware of the headlamp prices.
I am trying to see what the previous owner had done and how it could affect you now.
He changed the ignition and presumably the key, did he change the old chip into the new key? If not the car would not be able to start.
In the statement that I referenced you do not mention the the ignition switch or the key ring being included in the deal although previously you said they were.
Yeah it was a good deal I guess would've been better if it actually worked.
The prior owner changed ignition cylinder and key fob. I have the old key and without knowing if they've changed the chip, I did swap it over to see if it would start. Either chip will not start the vehicle and this is after taking ground off battery, draining memory and reinitiating the whole key learn process.
With original key fob, SKREEM and ECU the vehicles security acts as it should. Just three cranks and then nothing tho.
Thanks
