Old Aug 5, 2018 | 10:26 PM
Auto's Avatar
Auto
Default Re: Changed SKREEM, key & ECU no start!
Originally Posted by CL770
Hi Auto
I have mucked around with these things a lot and the method you are using should work. The only things that are matched are the ECU, the SKREEM and the chip in the key fob. Did you actually see that parts that you bought working in the donor vehicle? As it sounds like at least one of these parts doesn't match. I suspect that the key fob and the RFID chip do not match this SKREEM.
I was thinking the same thing but, I have noticed that the fob does operate the lock/arm on the donor SKREEM module. It just won't disarm or start mine. I believe I read somewhere that you can not program a used remote to a used SKREEM. They may have got me but the car was together and was for sale as whole or part and listed as running. No, I didn't personally see it run...just took their word. Just don't know if I want to put anymore in it and it still not start. Should have ordered the SKREEM from needswings but the title must be in my name which it is not(yet). Not going to pay taxes, tag and title fees if it won't start.
