Old Aug 6, 2018 | 12:57 PM
Speedy4x4's Avatar
Speedy4x4
Default Re: Maximum tire size on front and back?
Originally Posted by amx1397
you can rotate directional tires ,your front or rear BUT as i do you have to brake them down reverse the tire on the rim THEN they will go to the opposite side of the car. If you have a tire, lets say is wearing on the inside, flip it on the rim and now the wear is on the outside mount it on the other side of the car and the rotating direction is the correct direction
What I do, unmount and flip and remount, then put on the opposite side, so on the directional tires, what was in the inside is now in the outside.
but can not do on the continental dws they have a in and out instead of direction.
if you buy and install the tires at at shop that offers lifetime rotations with purchase, tell them, to rotate they have to unmount and flip and remount and balance, I would do evan if they where not directional tires with the high camber.
I have michelins 285, but also 19x11.5 rear wheels, do not use a 285 runflat on stock rims, they are not wide enough and will have problems seating.
if on stock rims heck ratings on tire to see if you can run a 9" wide wheel.
