Old Aug 8, 2018 | 09:53 AM
Tar Heel David's Avatar
Tar Heel David
Default Re: Engine Performance Problem
I had the same problem and changed the pump. It did fix problem. I found work around on the forum where you wire the pump through the fuse box to turn the pump on when the ignition is on. Fixed my problem. Must have been a bad heat sensor.
