Re: Engine Performance Problem
I would imagine that the secondary coolant pump to keep the intercooler coll is there for a good reason. So that you are not putting hot air through the intercooler and then pumping hot air into the cylinders when accelerating hard, causing predetonation. Am I wrong about this? I would guess it is not a good idea to bypass what the heat sensor is telling the ECM.
