Old Aug 12, 2018 | 05:20 PM
pct's Avatar
pct
Default Re: Chrysler crossfire
Originally Posted by BPD07
Welcome! There are a couple of good UK groups on Facebook, more active than here (which to be fair is more US based). The Mercedes 320 engine is strong and not known for gasket failures. I’d get an independent Mercedes specialist to look first. Yes on the battery, get a new one, so many unreleased gremlins stem from it. Car looks tidy, and yellow is quite a rare colour. Have fun on the recommission, and enjoy the drive.
yes these motors are not known for head gasket issues unless someone has cooked the engine after a coolant leak.
with the roof I would double check that the boot partition is clipped properly into place as this switches the power on and off to the roof, can you tell us if the car makes any attempt to open the roof? or does it make a bleeping noise when you try to open it?
it sounds like the car has been a garage queen, which can lead to electrical problems on any make, including a dying battery.
the wheel arch corrosion is fairly common amd easily sorted by a good paint shop, it happens because mus builds up in the badly designed inner lip of the wheel arch.
