Old Aug 13, 2018 | 02:23 PM
onehundred80
Default Re: Replacing the crankshaft pulley
Originally Posted by latemodel21
Since you MUST tighten this by hand (148 ft lbs and then 90 degrees), you might as well use the same tool to loosen it. I use the crank holding tool (with a short length of pipe slid over it so it gets a better hold of the frame) and then I use a 3/4" ratchet (harbor freight set is pretty reasonably priced) with a 3 foot pipe slipped over it to loosen (and then later tighten) the bolt
one thing that most folks overlook is that this is the PERFECT time to replace the $7 front crankshaft seal .... If you don't you will need to buy ANOTHER new bolt after you repeat the pulley installation process when you replace the crank seal. (don't oil the seal where the balancer slips through, this type of seal does NOT like that ... use a little spit on it if you want the balancer to slide in easy)
Hope that helps,
Chris
What am I missing here, how do you get 148 ft lbs without a torque wrench?
Using a pipe on a torque wrench requires a recalculation of the torque applied.
No oil is to be applied to the new bolt as that alters the torque applied.
