Re: Engine starts and stops after a few seconds
I changed the camshaft position sensor today with a new Bosch item - no improvement.
To recap:
car starts and runs for 2 - 4 seconds before shutting down. It does this again and again.
there are no current trouble codes
fuel filter has been replaced with new Bosch unit
relay control module has been replaced with new Mercedes unit
fuel pressure is good
cleaned the MAF
cleaned and reconnected the contacts on the PCM. No corrosion
crank position sensor and camshaft position sensor have been replaced with new Bosch units
trying to find a way to check for plugged cat/ exhaust, but think I’m going to have to unbolt the cats to test for this
any more suggestions PLEEEEEASE anyone?
