Re: P0300 Random misfire - HELP!!
Hi liljay, Thanks for your post. I think you win the trophy for the highest mileage Crossfire still operating on this planet! I have cat delete downpipes (from Needswings) and the car only has about 60,000 miles. I've had this issue intermittently before but now it's happening almost every time I tromp on the pedal to "make it go fast". Please post here if you discover the problem . . .
Hi TommyLT, Thanks for your post. I looked at the posts in that link. Nothing popped out at me that might be helpful.
Hi Padgett, Thanks for your post. I have an INNOVA 1360b ScanTool w/ABS-SRS. I need to pull out the instruction manual because I believe it is able to read the deeper codes too. When I got the P0300 code it showed it was 1 of 3 trouble codes but I couldn't seem to get it to display the other codes. You know the saying, "When all else fails, read the instructions!" DUH . . .
I'll be taking a fresh look at things tomorrow. Now that I think about it, it does act like a fuel issue rather than an ignition issue. I'll post more clues (or more hopefully results) as I stumble along tomorrow . . .
