Originally Posted by Space coupe
ha ! Thanks 😂 I do have one question but I've already seen the thread for it so I'll post there but I case anyone is curious before I post the thread.
Recently like as in a couple days recent, upon cold starts and even sometimes when I'm driving the speedometer and odometer stops working the spoiler deploys (regardless of speed and won't let me lower it back down) and the bas esp , abs , brake wear indicator & brake light all turn on. Not too sure why but so far the only correlation I've found is that like I said upon cold starts it happens
When the spoiler deploys when starting the car it is usually because the battery is weak and on its way out
This is the #1 thing to check as it might be time for a new battery
It should be holding 12.6 volts or better after parked and not running
This may be the cause of some of the other strange things you have mentioned too
Low voltage really messes with the Crossfire's
