Carlos99111
I have 2005 crossfire SRT-6 with almost 62,000 and my fog lights, side marker lights and tail lights won’t turn off. I have to jump start it or unplug the battery otherwise it drains my battery. My headlights don’t turn on. The turn switch is at the off position but they won’t shut off.
How long have you had this car?
Is the switch in the straight up and down position?
On Canadian cars those lights are used as daytime running lights and are timed off by the trunk mounted security pump. I am not sure if they are all kept on after lights have been used at night on US car and the ignition switched off, I know the fog light is and it is timed out by the pump in the trunk, so a faulty trunk pump may be the cause. Rain water leaks into the trunk and wrecks the pump, check for water down beside the pump after removing the trunk mat.
