Originally Posted by bengel
Almost sounds dangerous. How well does it stay mixed? I used to use a little nitro methane and it did not stay mixed with gas very well. Stayed mixed in alcohol just fine. Will the computer compensate for the more O2 and give it more fuel?
Nitro methane doesn't mix well with gas, as you probably know now... Nitro Propane and Nitro Ethane will.
The Propylene Oxide is an oxygenator, basically like having a NOS bottle in you gas tank. It does trick the 02 sensor into advancing the timing and richening the mixture. I ran the "HDDP version of Rocket Fuel" yesterday at the track and was smoking cars with much more HP than me.
I had one of my camera operators come out and shoot the event in HD. I've got some good video, but it will take me a few days to edit.
DYNAMIC S: Toluene is $13 gal. but only used as an octane booster to prevent predetonation from the Propylene Oxide which introduces 37% more Oxygen into your fuel and help prevent the ECU from retarding the timing. Unfortunately PO is friggin expensive. $224 for 5 gallons. Race gas at the track is now $7 gal. So, yes, you could just buy 101 race gas and then add the PO, but I like to scare my neighbors when I start mixing the stuff in my driveway !!!
