Re: Key won't lock or unlock doors
Ok guys need your wisdom and experience on this problem. The key will not go all the way into the door lock (works great in the ignition and gloce box). Took it to a lock smith, thinking something was in the lock, and he found nothing and using a small scope saw nothing. He squirting a solution into the lock without any siccsuc. Said I should take it to a dealer for them to remove the lock and see if any of the small pins and needles were missing.
Any suggestions before I take the door panel off (if I have to remove the door panel is there a link to assist/guide with the task?
thanks
