Old Aug 31, 2018 | 07:15 PM
nvrgvupjw's Avatar
nvrgvupjw
Default Re: oil leak at front bolt under A/C
Originally Posted by CL770
Hi
I don't think it would be coming out of any of those bolts. It's more likely to be coming from something above and ending up down there. I'd check around the power steering pump and there's a small plate on the front of the engine were it can leak. It could also be coming out of the valve cover. I guess I'm trying to say that you should have a good look elsewhere for the source of the oil.
Thanks for the reply. I've got it jacked higher now (with safety stands), so I can run the engine and check the places you mentioned. I don't see the small plate you mentioned. Is it behind the A/C pulley?
The valve cover gaskets are new and breathers just re-sealed with no leaks. It'd doesn't seem to be power steering fluid, but I'll re-check that.
