Thread: Car don't start
Old Sep 1, 2018 | 04:44 PM
MARTHA64's Avatar
MARTHA64
Default Re: Car don't start
If you turn the key to "ON" and the engine fan warps up to high speed, the engine control output of the RCM is not making it to the ECM.
IF you have resoldered the pins on the RCM, next step is to replace the relay on the RCM - that, or just order a new RCM from one of the aftermarket sources.
Or... send the RCM to TJ in Arizona.
IN a day or two, he will probably see this thread and respond.
no I didn't fix it I send it to TJ on Arizona hi did, the fan stopped after it got back and I installed, and before I change the skreem module the car didn't do anything, now after I installed the new skreem module the car only gives me one time start and no a second or third just don't do everything , if I disconnect the battery and connect it again the car goes to the same once start and dies again.
