Old Sep 1, 2018 | 05:35 PM
  #50 (permalink)
ZERACER
Default Re: Ignition switch ?
It will rotate in the fitting until you tighten the bolt. As long as you are able to push in the pin and slide it into the fitting as far as it will go you should only have to tighten the bolt to hold it in place.
