Old Sep 3, 2018 | 10:33 AM
John&Terry's Avatar
John&Terry
Default Re: Brake Lamps On/Electrical Problem
The stop light switch does more than operate the brake lights. It is also involved with the BAS/ESP system.
Thank you for this information. The picture helps identify the proper part, and the schematic helps a lot too. It clearly shows there are a lot of interconnections between the Brake Light Switch and Other Systems. I am also getting a bunch of other stored trouble codes: P1876-Traction System Communication Failure, P1817-Back Light Short, N49-Steering Angle Sensor, B1040,B1041-CAN Communication faults to Engine Control and Traction Control Modules. This information helps explain why I could be getting these seemingly unrelated trouble codes.
