pizzaguy
I'd change the switch, maybe the relay as well.
If things still act odd, I think I'd look the battery terminals over, clean them, check the condition of the battery ground cable connection to the chassis, verify the jumper from engine block to chassis is healthy and if I still have issues, replace the battery. Or at least keep it in the back of your mind that the battery may be going...
Thank you for this advise. I will replace the Stop Lamp Switch, if that doesn't solve the problem I can swap the relay out from my other car to see if that helps. I will also check the battery and connections. And this is a good thing to do anyway with winter coming. I already have a brand new Die Hard sitting in the garage on trickle charge.
I really appreciate everyone's help and advise. What a great car, and a terrific Forum. Thanks!
