BAS ESP/ ABS/ E Brake/ Brake wear indicator light all on
Sep 5, 2018 | 07:56 PM
permalink
Space coupe
Aug 2018
40
Maryland
Re: BAS ESP/ ABS/ E Brake/ Brake wear indicator light all on
Sorry for the late response..
UPDATE: So the correlation (somewhat) is that when the car is warmed up everything works fine *most of the time* ( no abs / bas esp hand brake or brake wear indicator light and the speedometer giving me a reading) So I decided to check on those solenoids like you said the middle 3 are engaging fine it's the outer 2 that won't engage in not sure what do or control but they won't engadge I've checked them while the car was malfunctioning and while it was working properly, no change so far.
I dont wanna take it to auto shop or dealer to get it looked at but at the same time it needs to get fixed
Idk how clear it is but the middle 3 are closed and the car is running
Running fine with the 3 solenoids engaged and outer 2 disengadged... Don't mind the gas light
Battery out putting 12.9 ~ 13 volts while not running
Space coupe
View Public Profile
Send a private message to Space coupe
Find all posts by Space coupe
