Old Sep 15, 2018 | 10:15 AM
amx1397
Default Re: Driveshaft length
Originally Posted by loggato
Does someone have a driveshaft they can measure from flange to flange?
I would like to compare it to a couple of Mercedes SLK driveshafts that I have laying around.
thank you
been there done that, none fit. the short section on some are the same but out of balance.
if you look where two halfs join (slip) you will see two notches on one half ,,, and one notch on the other ,,they need to line up when the driveshaft goes together for balance. do a search on driveshaft
