Old Sep 15, 2018 | 12:43 PM
CBISJN's Avatar
CBISJN
Default Replacing the Fuel Pump and Filter
I will be replacing my fuel pump and filter on my 2005 Limited roadster. I've seen posts where it is recommended to pull the fuel pump fuse and start the car till it runs out of fuel before replacing the pump, and I have also seen where it is recommended to remove the negative terminal on the battery as well. Doesn't removing the negative battery cable create an issue with creating a code and getting a check engine light? Trying to avoid getting any form of check engine light or codes after doing this.
I also found a great link to the service manual for the crossfire if anyone else is interested in getting step by step instructions on a number of repairs.
Chrysler Crossfire - service repair manual 2005 year
Thanks in advance.
