onehundred80
This is the cable, not a linkage. If you fix the sticky ignition you take it off the ignition switch.
this cable is (on auto only) it is to ,,when you push the brake ,it releases the shifter so you can get the tranny out of park, it also lets the key turn,,, it has nothing to do with no going fully into park, so you can remove your key .
