Old Sep 17, 2018 | 04:00 PM
onehundred80
Default Re: car won't start and key will not come out of switch
Originally Posted by amx1397
You are right and I am right, in our shop J S Benz and matt's shop we have had over 100 mercedes with 4 of those being crossfire's (key would not remove when in park) , replaced the bushing on the linkage,,,fixed.
quote: you can push the brake pedal on autos and take the tranny out of park, you cannot. end quote:
when key is in on position you can and only then so yes the cable does release the shifter,, a worn out bushing will (sometimes ) not let the transmission be in the gear showing on the dash , so we are both right.
But only with the key in the ON position,
This thread is about not having the key in the ON, but about getting the key out, and it will only come out in P.
The key has to be turned to the ON position to move the shifter and the cable allows that. It does not allow it to occur in the ACC position.
Both points are right but only one case is relevant on this occasion.
