phred7777
Just replaced front sway bar with AMG sway bar from NeedsWings. Big improvement for autocross feel and times. 8% thicker bar, solid hot rolled chrome moly and great bushings. Easy install. Had alignment shop add a bit more camber and toe for next race. Will see how that fairs.
Did it affect the stock balance or seem to increase understeer? I'm looking for improvement in stiffness and stability without compromising cornering. The H&R bar seems like it would be overkill and provoke more under steer. Are you able to measure the AMG bar? The thickness at the ends and in the middle?
Thanks
