Old Oct 10, 2018 | 04:41 PM
onehundred80
Default Re: Lock and siren troubleshooting. Need help!
I can say with 100% accuracy, it sounds like water in the lower trunk/hatch cavity. Check there and hopefully water damage didn't destroy the module there!
Can you lock all the doors using the fob?
Does the switch on the dash lock all doors?
The alarm issue looks like it was a false alarm.
It looks like the pump in the trunk is damaged maybe it will dry out, normally they are ruined.
If you have to get a pump, get one with all the plugs with it as your plugs may be ruined by corrosion.
These pumps are not cheap.
