Old Oct 10, 2018 | 09:55 PM
summerstar's Avatar
summerstar
Default Re: Lock and siren troubleshooting. Need help!
Can you lock all the doors using the fob?
Does the switch on the dash lock all doors?
The alarm issue looks like it was a false alarm.
It looks like the pump in the trunk is damaged maybe it will dry out, normally they are ruined.
If you have to get a pump, get one with all the plugs with it as your plugs may be ruined by corrosion.
These pumps are not cheap.
hi
dash lock can lock all doors and trunk.
remote lock and unlock is working,but lock and unlock by actual key on driver side won’t lock or unlock any doors except driver side door.
alram going off randomly when door is locked.
