Old Oct 15, 2018 | 08:56 AM
Cobrasrt8's Avatar
Cobrasrt8
Default Re: Slight vibration issue
Having them balanced again may or may not help. Tires have a heavy spot on them which is marked on the sidewall by a red or yellow dot. That dot should be opposite if your valve stem to counter balance each other. If they did not do that I would suggest to them to turn the tire on the rim and rebalance.
