Old Oct 22, 2018 | 10:16 AM
Toolman's Avatar
Toolman
Default Re: Lights in rocker panels
I have some about 6” long x 3/4” wide that say they are 100% waterproof and stick on with 3M double sided tape, maybe they might do with a bit more waterproofing.. I had forgot I had them till you mentioned them.
A trick to find the gap between doors and door jams, or air cleaner box and hood, is to use Silly Putty on one surface with the other side of the putty covered with plastic wrap. Shut the door or hood and it will squash the putty to the thickness of the gap. The plastic wrap stops the putty from sticking on the surface on that side.
