Old Oct 30, 2018 | 05:10 PM
ZERACER
Default adding top fluid
I believe the easiest way to add fluid to your top reservoir is to remove the driver side trunk panel, remove one screw from the controller and move it aside. You must pull up on it to remove it. You then have easy access to the plug and easy access to add fluid. A turkey baster and plastic hose works well. This is much easier thay trying to reach down through the top cover cover opening.
