Old Oct 31, 2018 | 12:27 PM
cheyoru's Avatar
cheyoru
Default Re: 65mm EC Clutched Supercharger Pulley VS ASP 178mm kit & PSK178
Originally Posted by velociabstract
I've had both on my car and prefer the 178 crank pulley BUT the installation is a bear/expensive/problematic. The supercharger pulley can be swapped on or off in 15 minutes or less which is a huge plus. The 178 makes more power than the 65mm pulley but it's close enough for some to call it a wash. The 65mm pulley is the easy button. I switched to a 178 with the PSK because my 65mm started rattling like a snake and I knew it would explode sooner than later.
Les
Thanks Les! Great advice.
How about reports of the 65mm causing a jerk/bump at about 10mph? Some say that a 178mm doesn't have that.
