Old Nov 4, 2018 | 08:31 PM
TNtech's Avatar
TNtech
Default Re: Suspected Current Drain -need advice please
The plastic spacers that contact the door ajar switches are a common issue. That C shaped trim with one tiny screw holding it on. Right around the latch opening on the door. If one side is missing I can promise you there is a draw. No amount of fuses you pull are going to tell on it.
