Old Nov 4, 2018 | 09:38 PM
James1549
Default Re: Suspected Current Drain -need advice please
Originally Posted by TNtech
The plastic spacers that contact the door ajar switches are a common issue. That C shaped trim with one tiny screw holding it on. Right around the latch opening on the door. If one side is missing I can promise you there is a draw. No amount of fuses you pull are going to tell on it.
Although I am not having an issue right now, I would like to know more about this issue. Can you explain more? thanks, James
