Old Nov 6, 2018 | 09:27 PM
  #50 (permalink)
DadsXF's Avatar
DadsXF
Default Re: stuck in park???
Originally Posted by JustinX
I had the rcm repaired by one of the forum members. It was tested in a manual crossfire. Mine is auto. The service manager printed out a service bulletin from Chrysler stating that if any modification or attempt to repair rcm may result in a lack of communication. My problem. I will look for a spare rcm on eBay. Just ordered a new cup holder off eBay for $102.00, since the car is fixed. I was debating selling it for parts. Chrysler parts in my area wanted $250.00!
JustinX - I realize this is an older thread, curious to see if you solved the problem. I have a similar issue, cannot shift out of park without using override. I had RCM repaired, for a no-start issue. It runs great, and after override, it behaves ok, shifts gears and acts normal. The indicator block on dash does not show the black rectangle, it does show the correct gear. I replaced the shifter module last weekend (and before that the brake light switch near the brake pedal with a part purchased from Mercedes dealer).
Did you ever solve your issue?
