Old Nov 14, 2018 | 11:50 PM
onehundred80
Default Re: Stuck in 1st! Help!
Originally Posted by Jlogan123
hey buddy did you ever figure out the problem my crossfire is stuck in 1st gear also and won’t go into reverse unless the car is turned off and restarted. Thanks
Your transmission has a fault, to prevent damage and to keep you moving the car goes into what is called ‘Limp Mode’.
The fault probably lies in one of the plates at the bottom of the transmission, get the trouble codes read and see if they point to a particular problem.
