Thread: Valve Stem Cap
Old Nov 20, 2018 | 05:18 PM
Toolman's Avatar
Toolman
Default Re: Valve Stem Cap
I don't know if it is across the board, but newer technology Tire Pressure Monitoring Systems do not need to have sensors programmed to the car. As an example, my Charger, and my wife's Renegade will automatically recognize new tire pressure sensors. The Crossfire has older TPMS technology that requires programming the sensors to the car using the Chrysler DRBIII or Starscan tools along with a small donut shaped magnet to trigger the sensor being matched/connected to the car.
Here are the programming procedures out of the 2004 factory service manual.
STANDARD PROCEDURE - TPM MODULE PROGRAMMING If a TPM module fails, or one or more tire pressure sensor/transmitters fail, after replacement, the TPM module’s diagnostic memory must be cleared and reprogrammed. This is necessary for the module to detect which wheel is sending the signal.Refer to the following procedure to program the module for identification of one new or all tire pressure sensor/transmitters.Note: The vehicle’s tires must not have been rotated above 8 km/h (5 mph) in the last two minutes prior to programming.1. Connect a DRBIII scan tool to the vehicle’s diagnostic connector beneath the instrument panel, to the left of the steering column.2. Access the Chassis System using the DRBIII. 3. Once in the Chassis System, select Tire Pressure Monitor.4. Select the appropriate function from the next screen displaying the following options:² Program LF Pressure Sensor² Program RF Pressure Sensor² Program RR Pressure Sensor² Program LR Pressure Sensor² Program Module (4 Sensors)Place a magnet, special tool 8821, at the valve stem for that wheel as directed by the DRBIII. If the Program Module function has been chosen, the DRBIII will direct you to the left front wheel pressure sensor/transmitter first. 6. When that wheel’s pressure sensor/transmitter has been programmed, the DRBIII will display Program Transmitter Complete or will automatically direct you to the next wheel sensor/transmitter to be programmed.Note: When programming the module (all four sensor/transmitters), the magnet should be moved from wheel to wheel in a clockwise direction starting at the left front wheel.7. Remove the magnet and if programming the entire module, move the magnet to each of the remaining wheels as directed by the DRBIII. Each sensor/transmitter will automatically sense the presence of the magnet and begin programming.8. Once Program Transmitter Complete is displayed, exit the program function screen.9. Verify that the module programming is complete by looking at the tire pressure sensor/transmitter ID’s in the Sensor Display using the DRBIII.
