Old Nov 21, 2018 | 01:29 PM
onehundred80
Default Re: Interior Lighting (Dome, Trunk, Glove Compartment)
Originally Posted by ROB311952
I'm sure there is some kind of module that controls these, but I don't know what it's called or where it's located. My dome light won't go on and off when I open the doors (switch is to the right). I can push in the button between them and it works, so I know it has power.
What is the module that controls the lighting called, where is it located, and is it easy to get to?
It is in the trunk on the right under the foam it is callledthe CLP/SSM. It is an air/vacuum pump and if it gets flooded it corrodes and fails. It controls a lot of functions.
Check for water down beside the foam under the trunk mat with a bit of stiff paper. The pump is a bugger to get to as the trunk panels have to be taken out unless you butcher the foam insert.
CLICK for details
