zip439
Use a scan tool and pull the codes; When the car did not start was the engine hot or cold. If hot, crankshaft position sensor is likely problem.
Hi Zip! It was hot...okay, I'll move forward with replacing the cam and crankshaft position sensors as they need to be done. I will also scan the codes and if there is anything odd I'll update the thread. Thanks for the insight, much appreciated.
