Old Dec 7, 2018 | 04:42 PM
Chiver79's Avatar
Chiver79
Default Headlight low beam not working. Bulb and fuse are good.
On my 05' Crossfire the passenger side low beam just quit working. Changed the bulb and checked the fuse. Still doesn't come on. Double checked the old and new bulbs, both measure resistance with my multimeter, so they should be good. Measured the fuse in the dash fuse panel with the headlight switch on, voltage at both fuse terminal tops. Measured voltage at the bulb connector, only .7v there. Is there a relay somewhere for the headlights? I know there's the bcm relay box by the battery, does this manage headlight power as well?
First post here for me, but I've been viewing for about a year now. Thanks in advance for the assistance and thanks a ton for all the information here I've used this year!
