Old Dec 8, 2018 | 08:29 PM
GraphiteGhost
Default Re: Headlight low beam not working. Bulb and fuse are good.
Originally Posted by Chiver79
On my 05' Crossfire the passenger side low beam just quit working. Changed the bulb and checked the fuse. Still doesn't come on. Double checked the old and new bulbs, both measure resistance with my multimeter, so they should be good. Measured the fuse in the dash fuse panel with the headlight switch on, voltage at both fuse terminal tops. Measured voltage at the bulb connector, only .7v there. Is there a relay somewhere for the headlights? I know there's the bcm relay box by the battery, does this manage headlight power as well?
First post here for me, but I've been viewing for about a year now. Thanks in advance for the assistance and thanks a ton for all the information here I've used this year!
I am hoping you are using a ground separate from the wire at the headlight bulb connector? Check Illumination Control Module (ICM) pins 3 and 5 for the 12v (system voltage) heading to the bulbs when set for headlights to be on. If pin 3 is not hot and pin 5 is hot, you may need a new or replacement ICM module. If both pins 3 and 5 are hot, you have an open in the wiring harness from output pin 3 to the headlight connector. Hope this helps!
