pizzaguy
Just keep in mind that electronics once wet, when dried out, will still retain any sediments or contamination from the water. In time, this will result in corrosion that can inhibit or conduct current.
If you start to see odd behavior in the next weeks or months, remember this.
A couple of years ago I purchased a Central Locking Pump to have as a spare from a salvage yard seller on ebay. The listing said it was tested and good. I didn't want to tear apart the coupe to test it, so I decided I would just check inside it to see if there was any corrosion. Removing the bottom cover revealed extensive corrosion inside the unit. I sent pictures to the seller and without any resistance he provided a full refund and didn't ask for the part back. It was useless to me so I tossed it. I recommend anyone buying a replacement either as a spare or to fix a problem to look inside it.
