Old Dec 17, 2018 | 10:01 AM
onehundred80
Default Re: Does anyone know the part number for this item?
Originally Posted by zip439
Try this:170-760-04-62-7E8 bezel, there are right and left ones. You may find the Mercedes number on the back side. I found it it in the lock and hardware category. Probably better to find one at a local junk yard. The silver handle part is a different number than the black bezel.
Are you sure the cable has not come undone, or fallen out of it's brackets as it leads aft towards the outer door handle? That is not unusual.
That number is wrong according to my records, a bezel is a trim piece and on the Crossfire the passenger side part # is A193 760 01 20, driver side would be A193 760 02 20.
The OP shows the inner part called a 'recess' in the SLK parts manual and the LH part# is A170 760 02 62, RH part# is A 170 760 01 20.
The LH handle is part# A202 766 01 24, RH part# is A202 766 02 24. I'll double check all these numbers as there is a mix of Crossfire and SLK part numbers as well as the 202 model number series.
The OPs photo shows the part rotated 180 degrees.
As stated in the previous post maybe the cable has come loose or broken. as that is what it looks like with the cable unattached, the handle just sags.
