Re: Convertible top problem
I manually lowered the top to rule out bad switches and it would not go back up electrically.
The pump is working but the top will not move and I get the infamous red lite in the switch and beep when the switch is depressed.
I know the pump is working because in order to put the top back up manually I had to release the pressure from the system.
Does this test rule out all the switches? My CLP was under water and I think that is the problem. I took it apart and dried it, it worked twice and then quit.
My battery is also going dead every two days or so now.
If the CLP is the problem is the problem does anyone know where I can get one and what the part number is?
Thanks Brian
