TPMS question
is there a way to check the TPMS sensors without actually deflating a tire to below whatever the level to set off the sensor and indicator light on the dash is?? i have no idea if the sensors on my srt6 have ever been changed, if they are good, or it the sensors go bad will it trip the dash light?? the indicator light on the dash does light with the key turned to the start position and goes off normally upon start as you would expect. additional..... i read the tpms thread that goes back to the year 1 and couldn't really find any conclusion regarding what to do if hey sensors finally go (assuming they haven't already and a previous owner did the #2 wire trick (but i doubt it since the indicator light shines when starting the car). bottom line has anyone actually found a real replacement that can be programmed by someone other than NASA since the dealerships apparently no longer want to work on our cars and those that do probably aren't qualified any longer, lol.. in simple terms: what is he correct TPMS sensors (universal frequency if possible) and who can properly program it??
