Thread: TPMS question
Old Dec 26, 2018 | 05:51 PM
onehundred80
Default Re: TPMS question
Originally Posted by srs244
thank you for taking the time to try to find it. i read until my eyes bled and came away no better off than when i started other than to come to the conclusion that without the chrysler scanner, cable, card and whatever else it needs, it is virtually impossible to use the OEM units if and when they go bad but no one has a definitive answer as to what will really work well and is affordable.
If your TPMS light is not on then your sensors are working, but if it comes on when the pressures are OK then a battery in one of them has failed and you need a new sensor.
You could buy the OEM sensors which are only able to be set by some dealers.
Or you could buy Schrader EZ Sensors basic part number 33500 which come with rubber valve stems or buy their part number 33700 which comes with the aluminum stem which looks like the OEM ones.
You can switch the stems on the 33500 sensors with the stem kit 34000 and you have a sensor that looks the same as the 34700 part.
Do not go to a dealer the parts cost more and you will still have to find a dealer who can confidently do it.
