Thread: Need Advice
Old Dec 28, 2018 | 11:31 PM
amx1397
Default Re: Need Advice
is it coming from front or rear? does it happen when you take off from dead stop? does it happen you give it wot( wide open throttle) or a hard (fast take off)? ok,,,,,, it is either the center bearing on the drive shaft ,,or it is the drive shaft.,if it is when going over a bump then it is the sway bar. jim
